THOMAS'S WEB SITE
Date:  2-3-2016
Number of Hours:  0.00
Brief Description:  Drilled Engine Mount Holes to the Firewall
First I had to mark the position of the 8 holes correctly.
Then I drilled the 8 holes (8mm) with a little drill stand for correct inclination. Worked out really well! I will need to grind off a little bit of the inner side from the 2 nose wheel pivot installations, because the engine mount touched these slightly.
